One field for relationships in both directions?
Hi all,
normally if you wants to connect items via relationship fields, you will have two fields: forward and backward relationship. So if you want to have both directions visible in each item, you have to show two fields. Is it possible to have both directions in one visible field, whcih is still usable by the user in a similar way like the normal ones?
Thanks, Jens
