RE: PTC Integrity - Create links with drag & drop
  • July 10, 2014
  • 1355 views
Hello together,
is it possible in the Requirements Analyst to create links (relationship fields) with drag & drop?
Thanks Michaela
Hello Michaela,
The Requirement Analyst ViewSet has many possible views that you can use. I'll try to address some of them here:
Normal item edits: If the relationship is valid, you can drag an item (for instance, from a query result set in which the item is an entry) into the relationship of a view of an item.
In the context of documents, you can drag content directly from one item to another, possibly while holding down the Alt (to create a trace) or Ctrl (to copy as a subsection at the target location) keys. Generally, the appropriate trace relationship fields will be filled in by the drag and drop action.
Is this what you were trying to figure out?
Kael
