Upgrade integrity server from 10.2 to 10.8 in one go?
  • April 21, 2017
  • 3180 views
We haven't upgraded our Integrity Server in a while and need to go from 10.2 to 10.8. Is it possible to upgrade directly to 10.8 or do we need to go from 10.2->10.3->10.4 etc.
I only ask because I remember doing one upgrade in the past where I skipped a release and it ended up missing a properties file (encryption.properties) due to a new feature that had been introduced in the previous release but was not created in the later release. Then I had to roll back and perform the intermediate upgrade before going to the next version.
Thanks in advance for any info.
Best regards,
Paul
    Best answer by tmisner
    Hello Paul,
    Is there any specific reason you are looking to upgrade to Integrity 10.8 specifically? We have recently released Integrity 11.1 and recommend upgrading to the latest version.
    First and foremost for an upgrade like this it is important to consider platform support. Please refer to the following documentation to confirm your current platforms are supported under the Integrity release you intend to upgrade to:
    Integrity 11 Platform Support
    https://support.ptc.com/WCMS/files/171619/en/Integrity_11_Supported_Platforms.pdf
    Integrity 10 Platform Support
    http://support.ptc.com/view?im_dbkey=142571
    Upgrade Path
    When upgrading from Integrity 10.2 to 10.8 you do not need to install every minor upgrade instance (i.e. 10.2 to 10.3 to 10.4). You will however need to install Integrity 10.7 before you can install any later versions of Integrity. The intermediary step to 10.7 is needed because a new table was introduced in this release. The aforementioned table provides a new model to store relationship data within the database. This new table was implemented because it scales much more efficiently than the previous table model it replaces. After the upgrade from 10.2 to 10.7 is complete data must be migrated from the old relationship table to the new relationship table. Please note the significant importance of this migration step. We highly recommend extensive testing of this data migration before it is implemented in production.
    For more information on the relationship data migration after installing Integrity 10.7 please refer to Chapter 2 starting on page 57 of the following guide:
    https://support.ptc.com/WCMS/files/164975/en/IntegrityUpgradingGuide_10_7.pdf
    Please be sure to read through Chapter 1 of the above 10.7 Upgrade Guide as well for more information on best practices and recommendations prior to upgrading.
    Similar Upgrade Guides are also available when upgrading to Integrity 10.8 or 11.1. They can be found here:
    Integrity 10.8 Upgrade Guide
    https://support.ptc.com/WCMS/files/168312/en/IntegrityUpgradingGuide_10_8.pdf
    Integrity 11.1 Upgrade Guide
    https://support.ptc.com/WCMS/files/172673/en/InstallUpgradingGuide_11_1.pdf
    Please be sure to read through these guides for best practices and recommendations.
    Hope that helps.
    tmisner16-PearlAnswer
    Hello Paul,
    Upgrade Path
    Hope that helps.
    padams1-VisitorAuthor
    Hi Tyler,
    Our IT matches releases of its solutions with specific versions of Integrity, so I have to use 10.8 in this case.
    Thanks for the info on the upgrade path, that is very useful. We will try it out on a test server first 🙂
    Best regards,
    Paul
    Also, since Integrity 10.8 is what you're planning on upgrading to, you'll want to make sure you install Integrity 10.8 hotfix  HF-S140000001-026
    (it replaces or supercedes the older mandatory hotfix HF-S140000001-022).  It's an important hotfix to avoid multi-edit issues on that version, if used.
