Versioning of Trigger Scripts and Report Recipes in Integrity Lifecycle Manager
  • August 13, 2018
  • 7497 views
How can we enable versioning of Trigger Scripts and Report Recipes in Integrity Lifecycle Manager?
Better  if this can be done using some solution related to configuration Management.
    Hi Chirag,
    Do you mean to store the trigger scripts & report recipe files in any version control tool?
    If this understanding of mine is correct, then you may use SVN / GIT / IBM Clearcase / Integrity SCCM or any equivalent tool depending on your company's standard policy.
    Grube,
    Kapil
    Hi Kapil,
    I am looking for a solution using Integrity SCCM, but how can I implement it.
    Chirag Agarwal
    Thanks for reply.
    We have tried MirrorTree.js script, as mentioned we did set the files at particular events in global.events but still the events are not getting called so the script is not executing. We believe that there might be some configuration issue from our side.
    Is anyone worked on this script, any input will be helpful.
    Thank you!
