View document with filter (via commandline)?
  • June 3, 2014
  • 2372 views
we would like to offer default document filter options to our users.
This could be done via custom command in the custom toolbar.
I found the CLI command "im viewsegment" that might work for us.
Unfortunately, the filter options (f.e. im viewsegment -g --filterrule=(field[Category]="Document") 4711) are not valid for use via CLI.
Is there another way to get predefined filters / a filtered document (other than manually selecting "show items containing...where")?
    Hello Stephan,
    The --filter* options are not going to be helpful, because they are intended for API use.
    If your users have access to a recent release of MS Word, you might be able to use the gateway export command, which supports both the --filterQueryDefinition=... and --filterQueryDefinitionFile options. This is detailed in the Gateway User Guide on page 25 (for version 10.5).
    I suspect the above is not what you're looking for, in which case my recommendation is to contact PTC Integrity Support to create enhancement request. Please reference this thread to the TSE, so that it can be updated with the RFC number and any other relevant information.
    Kael
    ssaul15-MoonstoneAuthor
    Hi Kael,
    yes, that's what we already did.
    We are attached to an existing RFC and will see when/if it will be implemented.
    Best regards,
    Stephan
    The RFC is
    RFC 912924.
