What is the simplest way to compute for numbers of days between states ?
  • July 31, 2015
  • 3773 views
I am looking for a way to compute for number of days between states in a workflow.  What would be the simplest option to take.  Also, it would be best if the resulting table can be downloaded to an excel spreadsheet so I can manipulate the data in various ways.
The object is to determine how long a specific state took to complete.
Hoping to get an answer soon.
PS.  I am not a developer or technical person.  I am more into project management.  But if this requires a specific technical approach I can have my developer look at it and try it out.
    Best answer by tketz
    hi Manolette,
    i think you want a field like "Days in Current State".
    Your Administrator has to define an integer field " Days in Current State" with the computation:
    IsEmpty(DaysCurrentState(), 0)
    With the export items to excel function you can export this field and modify it in excel (im not sure why you want to modify).
    If you need an matrix for every state you need a field for every state with computation like:
    DaysInState("STATE")
    Also you can get the Average Time in a State for a current set of items (Query):
    Query("Issues for Average days in state", Project, avg(DaysInState("STATE")))
    to display this information you need an item and/or create a report/dashboard
    I hope this helps,
    best regards,
    Tobi
    tketz1-VisitorAnswer
    hi Manolette,
    I hope this helps,
    best regards,
    Tobi
    mcruz1-VisitorAuthor
    hi Tobi,
    Sorry for not replying sooner as I was busy at work.
    Your answer is the same one that my developer suggested which means that we have to introduce new fields to save the number of days a project stayed in each STATE we want to monitor.   If we do this, I am thinking we need to define a trigger in each STATE that will compute the number of days in that state.  So if I modify my workflow and add new STATEs that means I would add new fields and new triggers for these fields to be computed.
    I want to ask if there was some other way to get the information without necessarily adding new fields.  I see that each project has a history log which shows the date/time and person who moved the project to the next STATE.  Can we retrieve this History log and maybe download it in Excel.  I was thinking of doing a weekly extraction where I can download logs which pertain to movements to next STATE for a given date range.
    If I have this, I could create a pivot table where I could display the STATES as columns for a single project giving me some sort of a timeline.  Once I have this I can then I can define calculation in excel to get number of days between STATES.
    Is the history even accessible to the users or is it only for INTEGRITY system use ?
    best regards
    Manolet
    Yes its possible,
    have a look at the Administration Guide->Computed Fields
    Use SecondsCurrentState() instead of DaysInCurrentState(). Now you have to calculate seconds to hours...
    But i don't understand your use-case for that. We calculate this field static (every night). If you want to calculate it live, you need enough performance...
