export gateway template >> exporting a field value of an upstream item <%{Validates:item .....
Hi PTC Community,
we are currently hustling while trying to adapt our gateway template.
Any help regarding to the problem written in the caption is highly appreciated.
At the moment we could only achieve to export the ID of a upward traced item – but not any other field value of this item of another hierarchy level.
The code <%{Validates}key=item field value (for instance “Assigned User”"%> or <%{Validates:item field value%> did not work.
All the best and regards
Daniel Remmers
Bausch & Lomb Technolas
