Hello, I'm using Tomcat/8.0.36 on Redhat 7, I have configured the JAVA path and everything works fine.
Database service is running also ..
When I want to access to apps in the webapps folder
What is the prob with that ?
What is in your application log located in thingworxstorage/logs ? Are you using the postgresql version? What is your platform version?
This is the log of ./bin/catalina.sh run
Attempting to load ESAPI.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: /ThingworxStorage/esapi/ESAPI.properties
Loaded 'ESAPI.properties' properties file
Attempting to load validation.properties via file I/O.
Attempting to load validation.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: /ThingworxStorage/esapi/validation.properties
Loaded 'validation.properties' properties file
java.lang.Exception: Unable to initialize and start system: Connections could not be acquired from the underlying database!
at com.thingworx.system.ThingWorxServer.loadModel(ThingWorxServer.java:534)
at com.thingworx.system.ThingWorxServer.doHA(ThingWorxServer.java:193)
at com.thingworx.system.ThingWorxBootstrapper.contextInitialized(ThingWorxBootstrapper.java:152)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4842)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5303)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:940)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1816)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
*** CRITICAL ERROR ON STARTUP: Unable to initialize and start system: Connections could not be acquired from the underlying database!
*** Web Application STATE is being set to ERROR! ***
I think it''s a database connection problem, but the postgres9.4 service working ...
Yes, it means the platform cannot talk to the database. Have you executed both of the scripts for database and schema setup when installing ThingWorx? Were there any errors? Could you please check pg admin III to see if there is a database "thingworx" with 58 tables created.
