9.3.4 Grid Rendering Hyperlink fixed text issue - Help
  • November 25, 2022
  • 1372 views
The mashup was created using 9.0 and the column displayed View until we upgraded to 9.3.4 and now displays [object Object]. The column renderer is set as follows; Column Renderer as Hyperlink, Format as New Page (_blank), Hyperlink Text Source as Fixed, Fixed Link Text as View.
Hello @unknown
Can you please share the screenshots to understand the issue more. If possible please share the sample entity too.
Attached is an image of the grid. The actual information in the column is a URL, eg "https://www.mycomapany.com/12358.docx". If rendered as text it displays the data. If rendered as a hyperlink it shows [objcet Object]. before upgrading to 9.3 it showed fixed text as a hyperlink "View".
