An installation of PTC Creo View is required in order to use this Widget.
  • August 29, 2017
  • 5471 views
Hi all,
I install Creo View Express 4.1 and ThingWorx 7.1.2-b6. I import the Creo View Widget into ThingWorx. But when I view the mashup, the browser reports me an error: An installation of PTC Creo View is required in order to use this Widget.
How can I solve this problem? Thanks a lot.
Hi Yijun,
I used to use Creo View widget before. As I know, you need to install Creo view on your PC and creo view  plug-in into your browser so that your browser can display 3D image.
Best Regards,
Lily
ydai1-VisitorAuthor
Where can I download the creo view plug-in for my browser?
Hi Yijun,
I consult with Creo View engineer, it should be Creo View Clients.
Best Regards,
Lily
