你好
我安装ATE的那天,我可以正常使用它,但它在第二天不能工作。
到期日期已更改。
这是命令“docker ps”和 “docker ps -a”的结果
谢谢
CCi_9
That may be causing improper shutdown of the containers.
Its highly recommended that you use the Analytics Shutdown utility prior to turning off your system.
It has been known to cause problems with the application in what we call violent shutdowns, which can corrupt containers or our microservices in the native installation.
- Neel
Thank you for posting your question to the PTC Community.
Unfortunately, I am only able to provide assistance in English. Are you able to provide what the issue you are facing is in English?
Neel
Sorry, I made a mistake
On the day I installed ATE, I could use it normally, but it could not work on the second day.
The expiration date has been changed.
here is the result of command"docker ps" and "docker ps -a"
CCi_9
Can you provide me a screenshot of any errors in Application Log and the Script Log?
ALso, have you reviewed this article, checking if the config connections IPs still match?
https://www.ptc.com/en/support/article?n=CS273969
Neel
These are the errors in Application Log and no errors in Script Log
I don't know whether the analytics.server.ip and microservices.server point to the right ip address and port
CCI_9
The Logs confirm the IPs got changed, and that you need to adjust the,.
You can see what IP is being issued by using the Docker list command for the containers.
Please try the article provided above as a possible solution to your problem.
Neel
Hello
I can't find what ip is being issued by using command "docker ps" and "docker ps -a"
thanks
CCI_9
ARe you able to log into Builder and check the settings tab?
Does the Analytics Gateway show in the drop down menu there?
If it does, can you remove it, then re-add it, verify, then save?
Neel
Hello
I have tried, but it still shows false
CCI_9
Can you provide a screenshot of the Settings Tab in Builder?
I am referring to this screen:
Neel
Hello
This is the screenshotthanks
CCI_9
At this time the only recommended action I can suggest is a uninstall and re-install.
Neel
Hello
I have tried much times, but everytime I re-installed,the next day it would occur again.
CCI_9
How are you stopping the Containers when you end for the day?
Are you just shutting down your computer, or are you using the Stop Utility that included in the Start Menu to stop ATE?
Neel
Hello
I just shutting down my computer,dose it matter?
CCI_9
- Neel
Hello
I see, I will have a try for it, thank you very much for your help.
Best Regards
CCi_9
