8-Gravel
February 4, 2026
Any CSV file generated by the Data Export mashup function is formatting any string data fields like
  • February 4, 2026
  • 2 replies
  • 114 views
Any CSV file generated by the Data Export mashup function is formatting any string data fields like an excel formula (ie string value: Example; in CSV file: ="Example").
This improper formatting is visible both in Excel as well as when opening the CSV file in a text editor like Notepad++
This issue only occurs when the Data Export option is set to "CSV Excel Formatted". When the Exporter option is set to "CSV Standard" any string fields are treated and formatted as plain strings. This workaround however comes with the warning: "Enabling this property allows users to export data in a non-sanitized CSV format. Use this option only if you trust the data source." implying that this option should generally not be used.
Inclusion of a BOM had no effect on this issue with either formatting option.
What can I do to prevent the improper formatting of the string data? The issue is affecting the ability of users to analyze the exported CSV data when needed.
Best answer by slangley
Hi @CC_13244540
This is a known issue.  Currently, it's not on the roadmap for redesigning this functionality.
You might want to review this similar post for some insights.   Also, PTC partner,  IQNOX, develops ThingWorx extensions/widgets.  They may have an alternative available.
Regards.
--Sharon
slangleyCommunity ManagerAnswer
Community Manager
February 5, 2026
Hi @CC_13244540
Regards.
--Sharon
Community Manager
February 17, 2026
Hi @CC_13244540
If you feel your question has been answered even though it may not be the answer you wanted, please mark my previous response as the Accepted Solution for the benefit of others in the community.
Regards.
--Sharon
