Attempt to update Axeda Platform Software Package through Groovy script failed
  • January 9, 2019
  • 3018 views
I'm using Axeda Platform 6.6 and when I tried to add  DownloadInstruction to Software Package and create or update the package with V2 API SoftwarePackageBridge I received the error:
An unexpected error has occurred. If you continue to receive this error please contact support and report the event
Some other instruction like RestartAgentInstruction added successfully.
What can  be a reason of such behavior?
Best regards,
Vadim Duchovny, Senior Software Engineer
Best answer by ckaminski
Hello, Vadim:
   Now I see what's going on.  You are mixing v1 and v2 APIs.  DownloadInstruction is a v1 API.
    You want to use the v2 DownloadFileInstruction:  com.axeda.services.v2.DownloadFileInstruction
     You will need to upload the file to the platform first to get a reference.  Please see the following link for more information on the process.
https://community.ptc.com/t5/IoT-Tech-Tips/REST-API-Example-Creating-a-Software-Package-with-File-Upload/m-p/534365
-Chris Kaminski
Hello, Vadim:
   Can you post the code sample you are using?
   6.6 had some unimplemented features, but the bridge features are also very particular in their inputs.
-Chris Kaminski
vadimd1-VisitorAuthor
See attached file (I renamed it from .groovy to .txt)
Before execution I verified that folder "/var/tmp/delivery" has valid file.
Thanks at advance,
Vadim Duchovny
Thank you very much, Chris, for excellent assistance.
I'll try to use the example you mentioned.
Best regards,
Vadim Duchovny
