Azure Iot enviroment variable set
  • January 5, 2022
  • 767 views
how to use Dconfig.file  & Dlogback.configurationFile in command prompt have to install anything for that ?
Hello @VS_10112707 ,
Kindly check the below mentioned link:
https://community.ptc.com/t5/ThingWorx-Developers/Setting-the-Environment-Variable-Azure-IoT-Hub/td-p/547073?posno=4&q=azure%20iot%20environment%20variable&source=search
And for the Complete guidance pls go through the PDF shared as attachment.
Kindly let me know if you have any further concerns.
Bhawna
