Binding Remote Thing
How do you actually bind to a remote property? The only way I have successfully created a Remote Thing in Thingworx so far is by using the New Composer and selecting the appropriate channel and device, then selecting the properties and binding to new entity.
I have tried the follow syntax to bind individual properties directly, with no success:
- channel1.device1.propertyName
- channel1_device1_propertyName
Is my approach wrong? I'm using Kepware and New composer --> discovery for connection. But I hope to make it more automated by using service to create the Remote Thing.
I also realised that when I try to detect remote properties under manage binding, it is empty when I create a new Remote Thing, but there are remote properties when I create via New Composer. So I must be missing a way to specify in the Remote Thing the respective device to point to. But I am not finding that option even when using the UI tool to create new Remote Thing.
Help is greatly appreciated! I do believe I have been going in the wrong direction for a long time
