Button disable state
  • July 19, 2024
  • 2 replies
  • 4088 views
Hi all,
I want to create this very simple logic... Disable a button for 3 seconds after clicked then enable again. It seems that this program has a way of making very simple logic ... complex for me.
Can anyone explain how this very basic feature can be implemented.
Best answer by Rocko
Something like this. The service is just a dummy for a longer running service.
You can use a autorefresh widget, enable the widget on click of button, configure it of 3 seconds, then on click of it enable the refresh and then the refresh widget can enable it again,
Okay, I will try to look into that. Thanks
Rocko
May I ask, why 3 seconds?
Its because the button activates a lot of services and it need to align with a timer in order to update my data correctly. So I want to disable the use the possibility of executing the button again before its done.
Rocko
Rocko19-TanzaniteAnswer
