C sdk quick start
Hi all,
I was walking through c sdk quick start guide from developer dashboard & got stuck at step 3 where after making necessary changes in main.c source file I needed to rebuild by issuing make command. I am using windows & as per instruction using vc++ build tools on it. The problem is make command is not available in my environment but there's one nmake & I am not being able to figure it out how to use the same. Can anybody help? Thanks in advancce
Thanks & Regards
Projjwal Ghosh
