Can't connect Raspberry Pi Properties to ThingWorx Composer - Error binding properties
- I have a raspberry Pi 3 set up and have my EMS running and the lua script resource running.
- The raspberry pi thing is showing isConnected as true on my Thingworx platform.
- The properties on the raspberry pi are updating every 30 seconds as instructed
- Thingworx Composer is open at localhost:8080/Thingworx/Composer
However, property values are not being pushed to Thingworx. My pi connection was working perfectly up until the middle of April and then wan't used at all until I tried to open my project again today.
Remote bindings are already set up but when I go again to the "manage property bindings tab" I get a message saying "Error browsing properties. Be sure the remote device/server is connected and configured properly".
I now also get the following message in my lua script repeated:
[INFO ] 2018-05-16 14:38:32,799 PiThing: EMS is available: true, online: true [WARN ] 2018-05-16 14:38:32,799 thingworx.server: Could not set properties on server. code: 500, resp: [DEBUG] 2018-05-16 14:38:34,305 thingworx.server: Created batch of 6 properties to be pushed to the server (last batch of group). [DEBUG] 2018-05-16 14:38:34,309 SDK: twTlsClient_Create: Initializing TLS Client [DEBUG] 2018-05-16 14:38:34,388 TlsStream::doclose: Disconeccting socket [DEBUG] 2018-05-16 14:38:34,389 SDK: twTlsClient_Close: Disconnecting from server [DEBUG] 2018-05-16 14:38:34,390 SDK: twTlsClient_Close: Disconnecting from server [INFO ] 2018-05-16 14:38:34,389 PiThing: Error occured while accessing EMS. Checking isConnected. [DEBUG] 2018-05-16 14:38:34,390 SDK: twTlsClient_Create: Initializing TLS Client [DEBUG] 2018-05-16 14:38:34,392 TlsStream::doclose: Disconeccting socket [DEBUG] 2018-05-16 14:38:34,392 SDK: twTlsClient_Close: Disconnecting from server [DEBUG] 2018-05-16 14:38:34,393 SDK: twTlsClient_Close: Disconnecting from server [INFO ] 2018-05-16 14:38:34,394 PiThing: EMS is available: true, online: true
Here is my config.json:
"ws_servers": [{
"host": "localhost",
"port": 9000
"http_server": {
"host": "127.0.0.1",
"port": 8000,
"ssl": false,
"authenticate": false
"appKey": "c9291758-bb3e-45e4-83a8-fb8b8abcff35",
"logger": {
"level": "DEBUG"
"auto_bind": [
"name": "PiThing",
"port": 8001,
"protocol": "http",
"identifier": "KitchenPiThing",
"gateway": false
"certificates": {
"validate": false,
"allow_self_signed": true
"ws_connection": {
"encryption": "none",
"verbose": true,
"msg_timeout": 10000
And my config.lua:
scripts.log_level = "DEBUG"
scripts.PiThing = {
file = "thing.lua",
template = "PiTemplate",
identifier = "KitchenPiThing",
scanRate = 1000,
taskRate = 30000
scripts.rap_host = "127.0.0.1"
scripts.rap_port = 8000
scripts.rap_ssl = false
scripts.rap_validate = false
scripts.script_resource_host = "127.0.0.1"
scripts.script_resource_port = 8001
scripts.script_resource_ssl = false
scripts.script_resource_authenticate = false
Thanks in advance,
Charlotte
