Cannot Login Using ThingWorx Authentication With an Empty Password when password is not empty.
  • March 14, 2019
  • 15064 views
Thingworx security logs sows an error "Cannot Login Using ThingWorx Authentication With an Empty Password" when password is type correct, i try normal users and administrator user always with the same error log. I just upgrade to  TW 8.4, and I did import files from a TW 8.3.
Community Manager
March 18, 2019
Hi @vguevaraperez.
This issue can occur if the password contains special characters.  Is that the situation here?
It appears you already have a case for this issue so once a fix has been found please come back here to post the solution.
--Sharon
Shannon,
My passwords does not have special characters.
And yes I will post the solution, I am taking with PTC Support.
