6-Contributor
May 16, 2023
Checkbox value changes when the service is invoked.
  • May 16, 2023
  • 989 views
I have a mashup parameter in a mashup say A which has a check box and by default its value is false. This checkbox's value is the input of a service which is used as an option to send email . I have another mashup say B which navigates to A . So the problem is even if i do not select the checkbox the service takes the input as true. Can anyone help me in this situation?
Thanks.
Best answer by DanZ
Either the binding is wrong or a default value is set in the mashup composer for the service.
Also could you share the code from your service?
DanZ15-MoonstoneAnswer
