Clickable location in the Map
We are using google map which reflects multiple locations in it. Is it possible to have those locations as clickable and on clicking those particular location, it should be able redirect to a new mashup.
These location are generated dynamically, so we cannot use static button widget over the map.
If we take an example, were we are pointing 5 different location over the map, so we should be able to click those location and individual location will be able to redirect to 5 separate mashup.
