Connecting external API into Thingworx
  • May 24, 2020
  • 2 replies
  • 3521 views
I am trying to connect external API into Thingworx.  But i am unable to receive responses.  I attached my code here.  and i upload my result also.  Please help me to do that.
Code:
var params = {
proxyScheme: undefined /* STRING */,
headers: { 'grant_type':'*****','client_id':'******','client_secret':'******','resource':'*******'},
ignoreSSLErrors: true,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: undefined /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: undefined /* STRING */,
url: "https://******", /* STRING */
timeout: 6000,
proxyPort: undefined /* INTEGER */,
password: undefined /* STRING */,
domain: undefined /* STRING */,
username: undefined /* STRING */
// result: JSON
var result = Resources["ContentLoaderFunctions"].GetJSON(params);
Did you test the API call before with a more "raw" tool like Postman or Curl?
DMu31-VisitorAuthor
It's working perfectly in postman... But I am unable to get response from thingworx...  Please help me to do that...
DMu31-VisitorAuthor
Hii,
Whenever i am executing my services, i am getting an output like connection reset.  I attached my screenshots below.  My url and credentials are perfectly working in postman.  Please help me to do that.
can you get the output for the above issue.I am also working on similar to your code.I am also getting the same issue
karthik
