Convert base64 code into Image
koushal
Hi
Can  someone help me converting base64 code into images?
I have check a similar post on this but that will use HEX code.
Please let me know if we can acheive this ?
In ThingWorx images which are not stored as files are base64-encoded strings. You don't need to do any conversion if you return IMAGE from your service, see screenshot attached.
/ Constantine
Vilia (my company) | GitHub | LinkedIn
PaiChung
22-Sapphire I
(To:koushal)
I know Thingworx has UUEncode and UUDecode services, so if the encode matches then the decode should be able to reconstitute the image.
koushal
(To:PaiChung)
I did not find these services. Could you please let me know under which Entity I will find these services?
Please let me know if any documentation available for these services.
Thanks for your response.
/ Constantine
PaiChung
22-Sapphire I
(To:koushal)
In the EncryptionFunctions there are Encode and Decode services.
