Correct Property Binding for EMC Devices
  • December 23, 2025
  • 2 replies
  • 122 views
What is the correct binding option for edge devices that connect via EMC? Should binding be set to "None"?
Alan
Best answer by CharlesJi
Hi @ablyth
Do you mean the 'Binding' settings under a specific property of an Axeda Agent Thing?
You should turn that option to 'Remotely bound' and specify the 'Remote Property Name' (e.g., the DataItem name from your Axeda Agent) if you want to bind a remote property from the Agent.
CharlesJi16-PearlAnswer
Hi @ablyth
Hi @ablyth,
Could you please check if the above post answers your question?  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
ablyth10-MarbleAuthor
Thanks for the reminder @CharlesJi , Accepted solution.
