Creating new user with permissions of creating new things,...etc?
  • October 16, 2019
  • 1535 views
I would like to create new users other than administrator, so it is possible that each user can work on different projects.
I have created new user and logged using
<host name>/Thingworx/FormLogin/<Organization>
But after logging in the user is not able to create anything.
Thank You,
Naeem
Best answer by raluca_edu
I recommend to look here: http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FComposer%2FSecurity%2FUsers%2FEntityPermissions.html%23
Please review all the section related to Security/Users/Groups as you need to give permission to the new user at the level of Design, Runtime, Visibility according to your business requirements. For example, if you need to permit user to create things, you need to provide Design time permissions, plus visibility at the level of organization/organization unit.
Best regards,
Raluca Edu
Best regards,
Raluca Edu
mnaeem1-VisitorAuthor
Thank you very much @raluca_edu. It's really helpful.
Instead of starting another topic, I would like to ask that how can I export a project from the ptcu learning server
https://ptcu-thingworx83-fundamentals.portal.ptc.io/Thingworx/logout/logout.html?locale=en.
I tried as follows but not working.
After pressing export it gives the following error.
Best Regards,
Muhammad Naeem Akhtar
Please open a new thread for this issue, for clarity on every thread.
Thank you,
Raluca Edu
