Custom extension using Eclipse
  • January 11, 2022
  • 1556 views
I am following this guide https://developer.thingworx.com/en/resources/guides/eclipse-plugin-thingworx-extension-development-tutorial/chapter-11-build-extension
I am having no sintax errors, as I copied the example code to be sure. But I can't build it after following every step. It gives me this only error
https://justpaste.it/4hudv
(I uploaded the error to justpaste.it because it is too long for this post)
I am on Windows 10
Eclipse Version: 2021-12 (4.22.0)
Build id: 20211202-1639
Best answer by MD_10146790
I used Ant instead of Gradle and it worked
1. Send your error log to technical support: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
2. Try the solution described here: https://giters.com/EddyVerbruggen/nativescript-plugin-firebase/issues/1850
MD_101467901-VisitorAuthorAnswer
