Datetimepicker widget changed event not triggering services
Thingworx 9.0.3
Dear @KN_9774047 ,
Do you mean no matter which service you bind Datetimepicker widget changed event to, this service would not be triggered in TWX 9.0.3 when DateTime changed? I just have a quick test in TWX 9.0.4, it works fine.
/Yoyo
Sorry!!
It is 9.0.2.Yes,Its not working what ever the service we bind to
Hi @KN_9774047 ,
I couldn't find a TWX 9.0.2 server in a short time so I cannot test it in this version. However, I did below two things:
How about importing the data I provided and check if the issue would happen? Then we can confirm that if this issue is a bug or not.
Note: run the 'TestThing' mashup at runtime and change the date, if the current time appears in the text box, it means the changed event triggers the showTime service.
/Yoyo
Hi @KN_9774047.
If the previous response helped you to resolve your issue, please mark it as the Accepted Solution for the benefit of others in the community. If the issue has not been resolved, please refer to the previous post for additional information to pinpoint the cause of the problem.
Regards.
--Sharon
