Dumping csv from Thingworx to cloud folder
VS_9760165
I am looking to dump csv file from thingworx to cloud folder example- Microsoft cloud.
Both will be in different network.
How can i do this in twx 9.1 version.
Thank you
Hi @VS_9760165 & @VaibhavShinde.
Are you running into an issue?  What errors are you receiving?  If you're just trying to move the CSV file to OneDrive, you could use an o/s scheduled task for moving the files.  If you still want to control it from ThingWorx, you can create a scheduled service to handle the move.
--Sharon
6 REPLIES 6
Microsoft Cloud? Blob? DB? OnDrive?
Hello @Sathishkumar_C
We are yet to decide which cloud , but here only this is cloud folder (consider One drive) where need to send csv file from TWX .
how to do this??
Vaibhav
You can use REST API to send a file to OnDrive.
Reference: https://docs.microsoft.com/en-us/onedrive/developer/rest-api/?view=odsp-graph-online
Hi @Sathishkumar_C
I am looking to send csv file on schedule basis (everyday 6pm) . i can't do it using Rest service.
can you suggest other?
Vaibhav
--Sharon
Hi @slangley
 transferring file from thingworx to Cloud Server Folder , When both twx and Cloud is on different network, Is Thingworx has OOTB services ?
i see there is only service in twx which uses to send file to Local folder not remote folder(different Environment).
Vaibhav
