EMS logging permissions errors on GetPropertySubscriptions call
  • September 16, 2015
  • 2 replies
  • 3080 views
I am able to make remote service calls and get returned data, however... I'm getting this polled repeatedly when I get connected with a device on my EMS
[INFO ] 2015-09-16 13:59:28,222 Truck000: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2015-09-16 13:59:28,251 Truck000: EMS is available: true, online: true
[INFO ] 2015-09-16 13:59:28,254 Truck000: Attempting to GetPropertySubscriptions from server failed. code: 500, result:
This is in the monitor under logs:
Unable to dispatch [ uri = /Things/*000/Services/GetPropertySubscriptions/]: Unable to Invoke Service GetPropertySubscriptions on Truck000 : Not authorized for ServiceInvoke on GetPropertySubscriptions in Truck000
The appKey I'm using to authenticate is hooked to "system" as User Name Reference.  Is this a permissions issue?
Best answer by Aanjan
Mike, if you are just testing, can you create an appKey with the Admin user and use that to connect?
Aanjan5-Regular MemberAnswer
mburke11-VisitorAuthor
I've changed the appkey user to Administrator and the error is still there.
Are you able to browse and bind the remote properties from the 'Manage Bindings' section?
Aanjan, I think I had some intermittent connectivity issues that were making it look like it still wasn't working.  The thing does seem to bind properly now.
