Edge DotNET SDK twCSdk.dll replacement
  • May 8, 2023
  • 2240 views
Download Path:
PTC Software Download -> ThingWorx Edge SDK -> ThingWorx Edge SDK -> Most Recent Datecode -> Datecode: M070 -> C-SDK-3-0-0-2317 (42 MB).
File name: MED-61061-CD-055_M070_C-SDK-3-0-0-2317.zip . Is this Edge C SDK source code? If yes, can I use it to build out twCSdk.dll (A) then replace into Edge DotNET SDK, DotNET SDK also have a tw-c-sdk folder installed, it also includes twCSdk.dll (B).
Want to customize Edge DotNET SDK, thanks.
Best answer by bchaudhary_448008
Hello @ZHH ,
I have checked and this twCSdk.dll  is NOT customizable. However, Could you pls share the features that are missing in the latest version?
Regards
Bhawna
Community Manager
May 19, 2023
Hi @ZHH.
Have you upgraded the .Net SDK to the latest?  It should already contain the updated .dll.  Here is a link to the .Net SDK release notes.
--Sharon
ZHH12-AmethystAuthor
Hi Sharon,
Already using the latest .Net SDK, want to add some features that the latest .Net SDK did not have, only add new features not change any existing as there is no .Net SDK source code.
Not sure if can replace twCSdk.dll with customized dll.
Thanks.
Hello @ZHH ,
Regards
Bhawna
