Error retrying to send an email to valid recipient error (reset password functionality)
  • June 2, 2021
  • 1840 views
I have a testUser inside a userGroup inside myOrganization
I configured SMTP Mail Server for Outbound Messaging (using outlook)
To test Service I use SendMessage method. It works fine
My problem comes after using reset password inside myOrganization login form.
I get the following messages:
 Warn User [testUser] is a member of [myOrganization] and has confirmed their personal information - sending reset email SuperUser S.c.t.s.a.ThingworxFormAuthenticator https-jsse-nio-8443-exec-56
then
 Error Error sending email to the following invalid addresses: null   S.c.t.t.m.MailThing https-jsse-nio-8443-exec-56
and finally
Error retrying to send an email to valid recipients after invalid ones caused a failure, or failure to send an error email about this event: 501 5.1.7 Invalid address_   S.c.t.t.m.MailThing https-jsse-nio-8443-exec-56
I'm not understanding the error or how to solve it, the email address is correct as I have confirmed it, it seems the email address is getting lost in some part of the function, Could you please give more detail on those messages and a workaround?
Please check if article CS341590  is useful to this issue.
Hello, I've been trying to make it work but I am not able to do so, I double checked the configuration for
Mail server (valid email, send message work fine, no reply, reply and error mails are correct too), organization, user information (fisrtName, lastName, emailAddress) and that user is part of composer group. However I am Still getting the message:
Normally we create a thing that extends MailServer, so do you check these configurations(Mail Account User,Default From Field,No-Reply Address,Reply Address,Error Address) of this thing instead of the MailServer template?
