Error while installing Analytics
  • March 19, 2020
  • 7878 views
I have installed Foundation, now I am working on installing Analytics. I got what i believe are the needed data (Key ID and Thingworx IP address.
I have attached screenshots of what I used and the error messages I got.
Any advice will be appreciated.
Best,
Ghandour
Best answer by Ghandour
Hi @cmorfin
Thanks a lot for your great help. I am talking about ANSYS Twin.
I will go forward and read the materials in the link you provided. I hope things get smoother from there.
Thanks again.
Best,
Ghandour
@Ghandour ,
Thank you for posting to the PTC Community.
I see in that attachment .docx, you are attempting to deploy ThingWorx Analytics using port 8080, but have SSL selected. Please verify that the port and SSL configuration are correct for the Platform Server you are using. Typically SSL is not used on the Dev Portal, so I would recommend deselecting "Use SSL?" box and trying again.
Neel
Ghandour1-VisitorAuthor
Hi Neel,
Thanks a lot for your reply. I deselected the SSL, but I still get the same error. Are the other information are obtained the way I described in the word file? or differently?
Best,
Ahmed
@cmorfin
Hi Christophe,
Thanks for your feed back. I tried it bust still not working.
I am using the info in the attached photo, but still get the same error.
I obtained the IP address from the page appears when I lunch the server. The Key ID is the one associated with: DevPortalAPP Key
Am I missing something here?
Ghandour
