Events as an input
  • June 15, 2021
  • 2 replies
  • 3476 views
The selected rows datas are taking time to pass input to expression/validator than events. Shall we pass Event as a input to expression/validator? Is that a good practice??
Best answer by abjain
@AP_9587236 : Yes these properties are not of type events. So these can be bound as input parameter to expressions and is fine.
@AP_9587236 : Can you please explain the use case here on what you are trying to achieve ? I don't think that binding events to expression parameters is possible but if you can explain clearly it would be helpful. If possible , please share some screenshots too.
Once the All Data of infotable values passed to Collection widget from service, we will get the options like Event:SNo, Event:Name,... as I highlighted in the below attachment for your reference. Binding those values to the "inputs of" expression/validator is efficient or not?
22-Sapphire I
June 15, 2021
Not quite sure what your question is or what you are trying to do.
But you can't 'pass events' you can use events to trigger.
So if you use selected rows, you can use selected row changed to fire the evaluation
Once the AllData of infotable values passed to Collection widget from service, we will get the options like Event:SNo, Event:Name,... as I highlighted in the below attachment for your reference. Binding those values to the "inputs of" expression/validator is efficient or not?
22-Sapphire I
June 17, 2021
For troubleshooting purposes, you can temporarily also add a value display on your mashup and bind the same values to those, this will help you see if they are changing or not.
For the expression widget to not fire at all is a bit strange.
I think you already set it to Always/Auto Evaluate right? (vs. Value)
