Export Infotable to Excel Document or create Print friendly view
  • May 8, 2015
  • 2 replies
  • 4837 views
Is there a way to create a service that will export a data table to an excel file for users to download when viewing a mashup? Is it also possible to create a more printer friendly version of an infotable listing information that needs to be scrolled through on a mashup?
Thank you.
    Hi Michael, the Data Export widget allows any data source in the mashup environment to be exported as CSV which you can then open in Excel.
    Unfortunately there currently isn't a printer friendly version of what you want.
    This would have to be a custom extension.
    Thank you for the help Pai!
    Sorry for open again this post but I'd like to know one thing:
    if I have a dashboard with several tabs, is it possible to place my data export button in the footer of the master and, when I click on it, it will download the data of the current tab?
    This means my button is responsive with my dashboard.
    Data Export button, exports an Infotable, a Dashboard it's not an Infotable. If on you current Tab, you have data that can be resumed to an Infotable, then you can bind this data to the export widget and it will do it.
    But you won't be able to know which Tab it's selected on the Dashboard, then it's not possible to export current Dashboard Tab.
    Carles.
