Expression code not saving
  • October 9, 2019
  • 2 replies
  • 2739 views
I'm trying to create an expression that simply takes a number (called 'shift') and returns a string like the following:
"This Shift ([shift])"
I tried creating an expression that takes 'shift' as an input and the expression code is simply:
"This Shift (" + shift + ")"
However, every time I try to create this expression, the expression code is empty the next time I open it and it doesn't actually work.
22-Sapphire I
October 10, 2019
What version of Thingworx are you using?
What you are doing looks correct, maybe try: result = ... or ' vs "
mdszy1-VisitorAuthor
I'm on 8.4.4.
I tried all combinations of using single quotes/double quotes and doing "result = " and none of that worked.
18-Opal
October 13, 2019
Hello @mdszy ,
It definitely looks like a good candidate for the Tech Support case. Meanwhile, just as a potential workaround suggestion -- try to export your Mashup as XML, modify the Expression code in the XML and import it back.
/ Constantine
Hi @mdszy ,If @Constantine  response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
