I am currently migrating projects from ThingWorx 9.3 to 10.1 and need to import several extensions required by the existing applications.
List of required extensions:
PTC.Base
CSVParser_Extensions
TWX_Converge_Core_ExtensionPackage
SCO_Common-extension
Twilio_Extensions
Mail_Extensions
TWX_Converge_Styles_ExtensionPackage
infotableselector_ExtensionPackage
FactoryDemo-extension
OA_OperatorAdvisor-extension
AppHomePage-extension
LogoutWidget-Mfg-extension
However, I am unable to determine whether any of these extensions have additional dependency extensions that must be installed beforehand.
I could not find a dependency list or reference on the ThingWorx portal or documentation that clearly specifies extension-to-extension dependencies for these packages with compatible version
Could you please confirm:
Whether any of the above extensions have mandatory dependencies on other extensions
If there is an official source, document, or tool within ThingWorx to verify extension dependencies before import
Hello Ayushi,
Please follow below order (independent extension)
After that follow below order (probably not exact)
Hello Ayushi,
Just a correction to Javed's response.....
Please be advised that the PTC Marketplace no longer exists--at least not in regard to ThingWorx extensions. There is a third party called IQNOX that develops ThingWorx extensions and extensions can also be found on github.
--Sharon
One other thing.....
Always check the PTC download site first for extensions for the relevant ThingWorx version before pursuing other options.
--Sharon
Hi Javed,
Thank you for sharing the extension import order and the detailed notes.
This is very helpful.
I’ll follow the sequence you mentioned during the import process.
Appreciate your guidance and support.
