Extension widget doesnt work with TW 9
  • September 13, 2021
  • 944 views
The attached extension contains a widget called gravity panel.
I can import this extension succesfully ( logs are OK),
but the associated widget (Gravity panel) is not visible when editing a mashup.
Best answer by ragrawal2
Hi @LaurentGermain
Did you try Reload Browser or clear Browser cache after importing the extension. When I try to import the attached Extension on ThingWorx 9.1 version I can import the Extension successfully and Gravity Panel widget can be seen in mashup Design time and runtime after reloading the Browser.
Ravi
ragrawal25-Regular MemberAnswer
Hi @LaurentGermain
Ravi
