Facing issue with Custom UI widget on first load
  • July 27, 2022
  • 2 replies
  • 4414 views
I have created a Custom UI extension using an External Library -Plotly. JS.
When I first load the mashup using View Mashup from mashup, the widget doesn't load properly, and when I click reload( not Tab reload, its the Reload button which shows up when we click on view mashup), it works perfectly.  And if I reload the tab completely, again for the first time it doesn't work properly
Another Scenario- I have added a contained Mashup and One of the mashups which loads in contained Mashup has the new widget. The first time I load the contained mashup with the UI widget, it does load properly. If I change the contained mashup and then change it back to the contained mashup( I have 2 buttons to load different mashups with different graphs in contained mashups) with the UI widget, it works perfectly.
Can someone help me how resolve this issue? Thanks in advance.
I am using Thingworx 9.1.6 version
Best answer by SaiKrishnaPola
Hi Team, After multiple follow-ups with PTC tech support, I did not find a solution for the issue.
But when I imported the Extension in 9.3 version, It is working fine. There seems to be an issue with 9.1.6 version
@SaiKrishnaPola ,
Did you create this mashup using Polymer or just plain javascript/html?
Nick
@nmilleson  I used plain JavaScript/html to create the extension
Thanks @SaiKrishnaPola,
If you inspect the html, does there seem to be any difference in DOM placement between the working and non-working one?
Nick
SaiKrishnaPola1-VisitorAuthorAnswer
