We have successfully imported the GitBackUp extension in my account and configured the Git credentials in the configuration tab of my thing. When try to call the Push we got the following error messages.
Push Error: java.lang.NullPointerException at gb.GitBackupTemplate.Push(GitBackupTemplate.java:221)
at jdk.internal.reflect.GeneratedMethodAccessor320.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at com.thingworx.common.processors.ReflectionProcessor.processService(ReflectionProcessor.java:230)
at com.thingworx.handlers.ReflectionServiceHandler.processService(ReflectionServiceHandler.java:50)
at com.thingworx.handlers.ServiceHandlerBase.processServiceWithMetrics(ServiceHandlerBase.java:48)
at com.thingworx.things.Thing.processServiceRequestDirect(Thing.java:8176)
at com.thingworx.things.Thing.processAPIServiceRequest(Thing.java:8113)
at com.thingworx.webservices.BaseService.handleInvoke(BaseService.java:3305)
at com.thingworx.webservices.BaseService.service(BaseService.java:489)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:227)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:162)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:189)
at com.thingworx.security.authentication.sso.SSOSecurityContextFilter.doFilter(SSOSecurityContextFilter.java:47)
at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:138)
at com.thingworx.security.contenttype.ContentLengthFilter.doFilter(ContentLengthFilter.java:73)
at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22)
at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:689)
at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:229)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:389)
at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:208)
at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:172)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:542)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:687)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:346)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:374)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:887)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1684)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:829)
also we created the personal access token in GIT and used it in password field, but that doesn't help.
Please provide a valuable solution for the above problem. thanks in advance.
As per the code, it can be an issue with getting the Git Repo object. Can you verify if your git repo url in the configuration is correct?
Thanks for the reply. The git url is correct only because I can able to pull data from git and also can view already committed changes.
