Fetch EMS Property value from lua file for remote binding
  • May 12, 2022
  • 1660 views
I have a Remote Thing and Property defined and binded properly.
When I try to update the Property by the sample lua code in EMS setup files, it is working properly.
But I need to fetch the data from elsewhere instead of hardcode and update in the remote property.
I am trying to update the property value from EMS by fetching the value from some a json stored in lua file in EMS.
Below is the code I used to fetch and Update the Value to remote property.
Property binding definition in Template file is as below.
properties.address_address1 = { baseType="STRING", pushType="NEVER", handler="script", key = "RemoteProperties/getRemoteBindPropValue" }
property Update Lua file code is below.
require "json"
require "utils"
require "tablex"
local deviceInfo = require("scripts.deviceInfo")
function getRemoteBindPropValue(method, path, headers, propertyInfo, data)
  local deviceInfoArray = deviceInfo.getDeviceInfo()
  for key,value in pairs(deviceInfoArray) do
    if key == propertyInfo.name then
      if method == "GET" then
      resp = json.encode({
      value = value,
      time = os.time() * 1000,
      quality = "GOOD"
      f:close()
      return 200, resp
    else
      f:close()
      return 405, "Only GET is allowed"
    end
   end
  end
end
log.info(p_data.name, "Registering HTTP callbacks")
tw_http.registerCallback("/getRemoteBindPropValue", "getRemoteBindPropValue")
log.info(p_data.name, "Beginning main loop")
while p_data.run do
tw_utils.psleep(1000)
end
Below is the list of deviceInfo I am trying to Fetch in the above function.
module("scripts.deviceInfo", package.seeall)
-- Edge Thing Profile
device_address = {
  address_address1 = "address1",
  address_address2 = "address2",
  address_city = "addressCity",
  address_stateOrProvince = "State",
  address_postalCode = "123456",
  address_country = "INDIA"
function getDeviceInfo()
  return device_address
end
Below is the error I am seeing the luascriptresource logs.
luaScriptProxy::executeScriptRequest: [4944] Error executing script RemoteProperties, Error = Error: ...ver\etc\custom\scripts\RemoteProperties.lua:27: bad argument #1 to 'open' (string expected, got nil)
[INFO ] 2022-05-12 14:29:25,288 RemoteProperties: To get property name path[2]: nil -nil -table: 034EAFD8 -table: 034EB230 -nil -path size: 1,
[ERROR] 2022-05-12 14:29:25,288 luaScriptProxy::executeScriptRequest: [4944] Error executing script RemoteProperties, Error = Error: ...ver\etc\custom\scripts\RemoteProperties.lua:27: bad argument #1 to 'open' (string expected, got nil)
[ERROR] 2022-05-12 14:29:25,288 luaInterscriptBinding::l_executeCallback: Error executing callback 'RemoteProperties//scripts/RemoteProperties/getRemoteBindPropValue'
Returned: 500 Error: ...ver\etc\custom\scripts\RemoteProperties.lua:27: bad argument #1 to 'open' (string expected, got nil)
[WARN ] 2022-05-12 14:29:25,288 TestEMSThing: Could not read current value of address_address1. Setting quality to UNKNOWN. Resp:
[WARN ] 2022-05-12 14:29:25,288 TestEMSThing: Error while getting property address_address1. msg: Error: ...ver\etc\custom\scripts\RemoteProperties.lua:27: bad argument #1 to 'open' (string expected, got nil)
[ERROR] 2022-05-12 14:29:25,288 luaInterscriptBinding::l_executeCallback: Error executing callback 'TestEMSThing//scripts/TestEMSThing/Properties/address_address1'
[ERROR] 2022-05-12 14:29:25,288 ScriptHandler::Callback: Error getting script result. Code = 500 Result = Error: ...ver\etc\custom\scripts\RemoteProperties.lua:27: bad argument #1 to 'open' (string expected, got nil)
[INFO ] 2022-05-12 14:29:39,335 RemoteProperties: To get property name path[2]: nil -nil -table: 0349A898 -table: 0349A708 -nil -path size: 1,
I have saved the reference to RemoteProperties.lua in config.lua file as below and the file is saved into the /etc/custome/scripts folder too.
scripts.RemoteProperties = {
file = "RemoteProperties.lua",
deviceName = "TestEMSThing"
Still I am seeing the script not found and not able to read the address details from the json.
The json files with the device details is also saved into the same scripts folder.
Any Help would be appreciated.
Please help me point towards what I am doing wrong here.
NOTE: EMS version is v5.4.10
Thanks and Regards,
Bhushan
Best answer by slangley
Hi @bmdeshmukh18.
Within the EMS download, there is a custom folder that contains the example template (example.lua) and scripts (sample.lua).  Example.lua contains examples of some properties that get their values from the sample file.  You can find it by searching for this text "-- Examples of Properties that access another script for their value".  The sample that's included has some functions that generate values (for simulating a working device), but you can use these functions for integrating with actual devices.  You'll have to write your own lua functions.  If you don't feel comfortable with lua, you can write your functions in another programming language, or you can explore using one of our other SDKs ( Java, .Net, C).
--Sharon
Community Manager
May 18, 2022
Hi @bmdeshmukh18
Can you confirm that this is correct and that it's returning the right string:
Also, is this the correct path for the config.lua file:  /etc/custome/scripts
An example is included in the download that may help to identify the cause of the problem.
--Sharon
Hi Sharon,
The key parameter is correct. I have tried to update the property value using default EMS setup. It works in that case.
But not when I want it to be fetched using some script.
Also the lua file containing the script, "RemoteProperties.lua" is present at "/etc/custom/scripts". The "e" earlier was a type error.
And the "config.lua" is present at "/etc/".
I did not find the download you were referring to.
Would you please be able to share that again if missed.
Thanks & Regards,
Bhushan
slangleyCommunity ManagerAnswer
Community Manager
June 2, 2022
Hi @bmdeshmukh18.
--Sharon
