Hi @gvyakaranam
Did you find a Solution? how can we edit thingworx-common.dll files?
Hi @PR_10128653.
The .Net SDK only supports .NET Framework, v.4.5.2 or later. Please refer to the Help Center for more information.
--Sharon
Hello @PR_10128653 ,
I have checked internally with our dev tem and it is neither advisable nor recommended to edit these OOTB files. However, the answer is yes you can edit ThingWorx-common.dll files. But if you decide to proceed editing these files, pls keep in mind that it may cause you upgrade and loss of existing projects.
Also, What is the purpose of editing these file? pls share your issue so that we can work on the real problem.
Have a good day ahead!
Regards
Bhawna
Hi @bchaudhary
I am facing some issue on the .Net Edge SDK , The below function is pointing to the Thingworx Dotnet Dll files, Will PTC Resolve those issues , if its not recommended to edit the dll files or is there any workaround solution is there?.
Unhandled exception. System.EntryPointNotFoundException: Unable to find an entry point named 'CopyMemory' in DLL 'kernel32.dll'.
at com.thingworx.communications.common.SecurityClaims.CopyMemory(IntPtr destination, IntPtr source, UInt32 length)
at com.thingworx.communications.common.SecurityClaims.twCopyMemory(IntPtr destination, IntPtr source, UInt32 length)
at RFIDReaderTwxEdge.RFIDReaderClient.<>c__DisplayClass3_0.<Main>b__0(IntPtr password, Int32 maxLength) in C:\QMWB\RFIDReaderTwxEdge\RFIDReaderClient.cs:line 83
at com.thingworx.communications.client.TwApiWrapper.twApi_Connect(UInt32 timeout, Int32 retries)
at com.thingworx.communications.client.TwApiWrapper.Connect(UInt32 timeout, Int16 retries)
at com.thingworx.communications.client.BaseClient.connect()
at com.thingworx.communications.client.ConnectedThingClient.connect()
at com.thingworx.communications.client.BaseClient.start()
at com.thingworx.communications.client.ConnectedThingClient.start()
at RFIDReaderTwxEdge.RFIDReaderClient.startClient(Object state) in C:\QMWB\RFIDReaderTwxEdge\RFIDReaderClient.cs:line 29
at System.Threading.QueueUserWorkItemCallbackDefaultContext.Execute()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading.PortableThreadPool.WorkerThread.WorkerThreadStart()
at System.Threading.Thread.StartCallback()
C:\QMWB\RFIDReaderTwxEdge\bin\Debug\net6.0\RFIDReaderTwxEdge.exe (process 7388) exited with code -532462766.
Hi @PR_10128653.
--Sharon
HI @slangley
The Thingworx .Net SDK is not working in the .Net Framework 6 .
My Target .Net Framework version is 6 , is it TWX .Net SDK tested on .Net Framework 6?
Hi @PR_10128653.
I checked the Microsoft site for .Net Framework downloads and the latest one I found was 4.8.1. The recommended version is 4.8.
Can you confirm the version of your o/s? Where did you get .Net Framework 6?
--Sharon
HI @slangley
Thanks for the Reply. My OS Details are
Windows Edition: Windows 10 Enterprise
Version:22H2
Latest .Net Long Term Support Version is :.Net 6.0 .16 which was released at April 11,2023
.Net Download URL: https://dotnet.microsoft.com/en-us/download
Hi @PR_10128653.
That's good to hear!
Please mark the appropriate response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
Hi @PR_10128653.
As previously advised, .Net SDK 5.8 only supports .NET Framework, v4.5.2 or later.
Please let me know if you have further questions.
--Sharon
