I want to verify whether a project is an extension. Using the code snippet below, we can retrieve a list of all extensions and iterate through them. However, in our case, the project name and its extension name might differ. How can we identify it in such a scenario?
result = Subsystems["PlatformSubsystem"].GetExtensionPackageList();
The same subsystem has a GetExtensionPackageDetails service which accepts as an input the name of the package you get from the service you mentioned. The output is the list of entities, including their type.
