How connect to direct mashups without login account?
  • July 25, 2017
  • 2 replies
  • 2839 views
I want connect to mashups without login account
so I setting visibility the mashups to Everyone but the mashups do continue to require login account
why need to connect without login account is because of mashups for create account
Best answer by posipova
Please look into using Appkeys to access: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS227935&lang=en_US
posipova20-TurquoiseAnswer
20-Turquoise
July 25, 2017
SOHEE1-VisitorAuthor
thank you~
20-Turquoise
July 28, 2017
If the answer helped you resolving your issue, could you please mark it as correct? This will help improving our community searchability. Thank you!
