I want connect to mashups without login account
so I setting visibility the mashups to Everyone but the mashups do continue to require login account
why need to connect without login account is because of mashups for create account
How connect to direct mashups without login account?
Please look into using Appkeys to access: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS227935&lang=en_US
thank you~
If the answer helped you resolving your issue, could you please mark it as correct? This will help improving our community searchability. Thank you!
