How could a chart be imported and used in thingworx?
  • March 13, 2017
  • 2166 views
Hi!!
I have created a chart using eclipse with html ang javascript.
How could I import and use that chart radar chart in thingworx?
Is there any easiest way to do that??
Hi Bavithraa, i believe this was already discussed (please do correct me if i understood it wrong) in one of your own thread Web shaped chart available??
It will require you to package up your custom chart/widget and then have it imported into ThingWorx, you can check your above thread to reference the documentation on how you can do this as it does include step by steps process on importing the custom widgets, built using ThingWorx Extension, to be imported in ThingWorx.
March 13, 2017
Sushant!! I have created my chart in eclipse. But I dont know how to modify my code according to the thingworx plugin in eclipse
