How old data is being retained by services QueryAlertSummary and QueryAlertHistory from current date
Explain the difference between these two services.
Thanks in advance
Thanks in advance
Hi
When running the services in Composer, the number of records returned is limited to 500. If you need to pull more, then you need to design a mashup to display the data. This will allow you to pull ALL data if needed regardless of timeframe.
--Sharon
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
