How to Get All Users from a Specific User Group in ThingWorx?
  • October 16, 2025
  • 998 views
Hi everyone ,
   I’ve been working with user management in ThingWorx and came across a related use case to this post
https://community.ptc.com/t5/ThingWorx-Developers/How-to-Find-all-User-Groups-for-a-Given-User/m-p/1038382#M70705
about getting all user groups for a given user (using Users[principal].GetGroups()).
Now I want to do the reverse:
Get all users that belong to a specific User Group? is it possible?
Thanks in advance for your insights!
Best answer by nmutter
you can get the direct members of a usergroup like
let result = Groups["Administrators"].GetGroupMembers();
result e.g.
- "Administrator" - type User
- "SomeOtherGroup" - type Group
This will also include contained groups (indicated in the result in the "type" column - group or user). To get also indirect members you would need to iterate over the contained groups and get all members, and repeat. But watch out as TWX groups can create a loop which you must detect and stop iterating a 2nd time.
nmutter16-PearlAnswer
result e.g.
MA873117416-PearlAuthor
Thank you! do you also have any clue that if there exists also a function with which we can remove all the users which one group has in it?
sure: In script editor either with autocomplete or with the "Me/Entities" feature:
Or via via REST API e.g. <yourhost>/Thingworx/Groups/Administrators/ServiceDefinitions
For Things its easier as you can see the services in Composer directly.
