How to call Java from JavasScript service ?
  • November 12, 2020
  • 2 replies
  • 1620 views
The engine that's used by ThingWorx JavaScript service is Rhino, it supports calling java directly as following :
. However , the similar usage doesn't work in ThingWorx JavaScript Service :
How to make it work in JavaScript service ?
Sean
Hello @seanccc,
Have you tried using with output string :
var pi = Math.PI;
result = Math.PI;
Hope it helps,
seanccc17-PeridotAuthor
@Ciprian-Traian ,
Thank, you .  var pi = Math.PI;  works,  but I got the same error when doing further testing :
============Rhino debugger=============
============ThingWorx============
Sean
Java primitive and classes are not exposed in ThingWorx Script Services.
You can create Java entities and services using the ThingWorx Extension SDK.
Tutorial : https://developer.thingworx.com/resources/guides/eclipse-plugin-thingworx-extension-development-tutorial
@smainente ,
Do you know the reason why the java primitive classes are not exposed ?   it  bring lots of convenience for development.
Sean
