How to change the tooltip format of a Bar Chart widget
- May 10, 2023
- 2 replies
- 1743 views
I am currently using version 9.3.8. My mashup has a "Bar Chart (ptcschartbar)" that is loaded by an infotable containing values with thousands separator and decimal places. The widget has a property - ValuesTooltip - with the value of "BarChartDefaultTooltip" which in my localization table (pt_BR) has the value of "${label}, ${series}: ${value}". How can I change the format of the ${value} field to my language (Example: 123,456.78)? The attached figure shows the value without formatting.
ps. In my previous version (9.3.2) I used a "Label Chart" and the tooltip was shown with the correct format (attached figure too).
