We would like to exchange data in both direction thru MQTT in twx.
We decided to use MQTT in twx using X.509 client certificate to connect IoT Core. Is there a way to connect via this method than the plain username and password in a secured way ?
Hello @sabharees ,
pls check the below given link for the various MQTT options available in Thingworx:
Pls let me know if you need anything further.
Regards
Bhawna
